268k mile tranny moves a little, replacement doesn't budge!
95SCORT
Hi there, I have a 1996 Ford Aerostar with the 4.0L V-6 which ran perfectly up until mile 268,797.1 The van was towed home but still moves itself when the engine is revved very high. Racing the engine I was able to drive it into my garage and replace the transmission and torque converter with a tranny and torque converter from a '96 explorer. with only 87k miles. Well the swap went well with only the only visible difference being an additional plug present in the explorer's tail shaft.
Making sure there is fluid in the torque converter and transmission I start up the van and put it in gear which no response is felt, I leave then van running in drive for about ten minutes but it still doesn't shift go into gear(transmission doesn't physically engage into gear but the column shifter shows transmission is in drive.
I am very stumped right now and am wondering if I missed anything!
btw, the old torque converter makes rattling sounds when shaken as if something inside fell apart.
Any ideas will be greatly appreciated!
Thank You!
Aug 2, 2007 at 11:20 AM
  • 75,988 POSTS
[quote:4cf09d87bb="95scort"]Hi there, I have a 1996 Ford Aerostar with the 4.0L V-6 which ran perfectly up until mile 268,797.1 The van was towed home but still moves itself when the engine is revved very high. Racing the engine I was able to drive it into my garage and replace the transmission and torque converter with a tranny and torque converter from a '96 explorer. with only 87k miles. Well the swap went well with only the only visible difference being an additional plug present in the explorer's tail shaft.
Thank You![/quote:4cf09d87bb]
Safety first, Try manually engaging it from the tranny and see what happens.
Aug 2, 2007 at 12:19 PM
95SCORT
[quote:29d6acb730="rasmataz"][quote:29d6acb730="95scort"]Hi there, I have a 1996 Ford Aerostar with the 4.0L V-6 which ran perfectly up until mile 268,797.1 The van was towed home but still moves itself when the engine is revved very high. Racing the engine I was able to drive it into my garage and replace the transmission and torque converter with a tranny and torque converter from a '96 explorer. with only 87k miles. Well the swap went well with only the only visible difference being an additional plug present in the explorer's tail shaft.
Thank You![/quote:29d6acb730]
Safety first, Try manually engaging it from the tranny and see what happens.[/quote:29d6acb730]
Tried it, no change.. :( reverse light comes on when shifted in reverse but it still doesn't engage into reverse mechanically, I am re-checking the connections which go to the transmission to make sure everything's tight, Thank you for your response!
Aug 2, 2007 at 12:23 PM
  • 75,988 POSTS
Not trying to be funny-been here before where they didn't bolt up the converter to the flywhee/flexplate.
Check the linkages-if coming internally you need to have a pressure test done.
Aug 2, 2007 at 1:33 PM
95SCORT
[quote:a9455f2c42="rasmataz"]Not trying to be funny-been here before where they didn't bolt up the converter to the flywhee/flexplate.
Check the linkages-if coming internally you need to have a pressure test done.[/quote:a9455f2c42]
Thank you very much! Yes I bolted the torque converter to the flywheel w/all four bolts of the torque converter. Explain the pressure test, is there a needed amound of pressure in my replacement transmission? I would assume it(the new transmission) lost pressure once removed from the explorer.
Aug 2, 2007 at 1:40 PM
