The check engine light came on. When the code was read it say Bank 1 and 2 are too lean. What could cause this?
Mar 14, 2009 at 12:09 PM
FORDTECH1966
MEMBER
I suspect you have a PO171 and PO174. There is a technical service bulliten on this issue. the codes are caused by a vacuum leak internally. The bullitin calls for replacement of the upper and lower intake gaskets, thefuel pressure regulator hose, and possibly the front valve cover.
