1999 Ford Aerostar want start
1999 FORD AEROSTAR
SFRENCH9591
Engine Mechanical problem
1999 Ford Aerostar 6 cyl Front Wheel Drive Automatic
i ran out of full an dit stop. i put more full in it about 2.5 gallons.it will turnover but it will not start. i was told there might been a braker switch that might have trip. haopr you can help me thanks
Jun 25, 2008 at 7:33 PM
BLACKOP555
  • 10,386 POSTS
running the fuel tank out or low on gas is a very good way to have contaminents sucked up in to the system and pump and it usually blows the fuel pump out, do you hear it when the key is turned to the on posiiton?
Jun 26, 2008 at 1:36 AM
SFRENCH9591
were is the feul pump located
Jun 26, 2008 at 6:20 AM
BLACKOP555
  • 10,386 POSTS
the fuel pump is located inside of the fuel tank!
Jun 26, 2008 at 3:29 PM
