1998 Ford Aerostar trouble codes
1998 FORD AEROSTAR
115,000 MILES • 6 CYL • FWD • AUTOMATIC
STEVE71
vehicle has lost power,seems to have 1 or 2 dead cylinders. there is no water in oil,spark plugs looked somewhat dirty. i cleaned gapped and reinstalled them and it still misses. im thinking fuel injector .the trouble codes are p1537 p1538 p0171,too lean bank 1
Nov 16, 2008 at 3:30 PM
  • 110,244 POSTS
Hi:
Code P1537 - Intake Manifold Runner Control Stuck Open
Code P1538 - Runner control stick
Code P0171 - System too lean bank 1
The runner control can cause the lean situation. The part is a big job to replace, but I have an idea. It is probly just the clip that conects to the actuater bar. Remove the Intake plentum first just to see. It's just a little clip no bigger than an eraser on a pencile. Anyway, it's not a real hard job, just time consuming. If you can use a torque wrench. It will take about 4 hours to complete.
Let me know what you find.
Nov 21, 2008 at 4:15 PM
