1998 Ford Aerostar MOTOR WONT IDLE WHEN HOT
1998 FORD AEROSTAR
85,000 MILES • 6 CYL • FWD • AUTOMATIC
CEASER69
WHEN THE MOTOR IS HOT IT DONT WANT TO START, WHEN IT STARTS IT DONT WANT TO IDLE
WHEN YOU PUT IT IN GEAR IT WANTS TO STALL
UNLESS YOU GIVE IT ALOT OF GAS THEN IT CHUGS
UNTIL ABOUT 5 TO 10 MPH. NO ENGINE LITE COMES ON. WHEN COLD IT WILL START AND RUN
FINE UNTIL IT GETS HOT. WOULD A TPS DO THIS
WITHOUT AN ENGINE LITE ?
Aug 26, 2009 at 4:06 AM
  • 110,240 POSTS
I would think the tps would set the light. Have you checked the egr valve? Vacuum leaks? fuel pressure?
Sep 10, 2009 at 3:01 PM
