1997 Ford Aerostar won't start cranks fine but just won't t
1997 FORD AEROSTAR
15,300 MILES • 6 CYL • AWD • AUTOMATIC
FINK38
I was wondering if maybe the fuel pump or the fuel injectors were bad?? The car will crank but it just won't turn over.
Jan 7, 2010 at 1:03 AM
No start condition:
Disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 in away from ground have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Jan 7, 2010 at 1:21 AM
