1997 Ford Aerostar ignition coil
16,000 MILES • 6 CYL • AWD • AUTOMATIC
CHUCK SARKELA
The "check engine" light came on a couple months ago. Computer diagnostic indicated mis-fire on #5 cylinder. I installed new spark plugs & wires, engine ran fine for about 2,000 miles, but the "check engine" light reoccured. Computer diagnostic again indicates mis-fire on #5 cylinder. The mechanic suggested replacing the ignition coil. This doesn't make sense to me ... how does the ignition coil function? Can it affect only 1 out of 6 cylinders? Where is the coil located? Is it difficult to replace?
Vehicle has a 4.0 liter V-6.
VIN# 1FMDA41X5VZB43252
THANK YOU & MERRY CHRISTMAS
Chuck Sarkela
Dec 21, 2008 at 3:55 AM
  • 110,248 POSTS
Chuck:
The coil is what creates the spark / power for the spark plugs. It is hard to believe that a coil can pick and choose what cylender will have a problem. If you remove the spark plug from #5, what does it look like? Also, you may want to check the compression in that cylender to make sure it's not low.
Let me know what you find.
Dec 30, 2008 at 4:06 AM
