1997 Ford Aerostar heater core -replace
11,800 MILES • V12 • 2WD • AUTOMATIC
JERRYKLECH
is dripping coolant and smell like coolant inside of the van .how to replace heater core?
Jan 15, 2009 at 1:24 PM
DAVE H
  • 13,383 POSTS
HEATER CORE
Removal & Installation
Drain cooling system. Disconnect heater hoses from heater core. Remove plenum access cover screws. Remove access cover. Remove heater core from plenum assembly. To install, reverse removal procedure. Add coolant as required. Check for leaks.
Jan 15, 2009 at 1:35 PM
