Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Aerostar
Climate Control
Heater
Heater Core
1997 Ford Aerostar heater core -replace
1997 FORD AEROSTAR
11,800 MILES • V12 • 2WD • AUTOMATIC
JERRYKLECH
MEMBER
1 POST
is dripping coolant and smell like coolant inside of the van .how to replace heater core?
Jan 15, 2009 at 1:24 PM
DAVE H
Experienced Mechanic
HEATER CORE
Removal & Installation
Drain cooling system. Disconnect heater hoses from heater core. Remove plenum access cover screws. Remove access cover. Remove heater core from plenum assembly. To install, reverse removal procedure. Add coolant as required. Check for leaks.
Jan 15, 2009 at 1:35 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
