1997 Ford Aerostar Head Gasket Replacement
1997 FORD AEROSTAR
147,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAN SPIN
  • 6 POSTS
I'm considering replacing the head gasket in my Ford Aerostar. Considering the access to the engine compartment I can't imagine that there is any way to do this without removing the engine from the vehicle. How many hours should I expect to spend on this repair? And are there any special tools I'll need or problems I should anticipate? Or should I sell the van for parts?
Thanks,
Jan
Jul 29, 2008 at 12:56 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:d10c0df173="Jan Spin"]Engine Cooling problem
1997 Ford Aerostar 6 cyl Two Wheel Drive Automatic 147000 miles
Thanks,
Jan[/quote:d10c0df173]
Hello Again Jan,
May I ask why you are considering replacing the Head Gaskets.
What problems are you having with the vehicle?
Jul 29, 2008 at 1:23 AM
JAN SPIN
  • 6 POSTS
The coolant leaks. I can't drive more than 2 miles without having overheating issues. I'm afraid this will kill the engine if I let it go too long.
Jul 29, 2008 at 1:42 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Are you able to get a rough idea of were the leak is? and I gather it is a pretty big leak if you can only go a couple miles.
Ex: front of motor, right side, left side, rear .....
Possible causes other than the head gasket are: Water Pump, hoses, freeze plugs....
Also how old are the hoses?
Jul 29, 2008 at 1:55 AM
