1997 Ford Aerostar air conditioning
164,000 MILES • 6 CYL • 2WD • AUTOMATIC
ZZZMAN1255
air not coming out of vents only out of the defroster vents and is not cold
Jun 10, 2010 at 12:28 PM
  • 110,248 POSTS
First, I think you may have a couple different problems. As far as the vents not working, you have a vacuum leak. It could be under the dash or the hood. The vent doors are actuated by vacuum. If there isn't enough, it will blow out the defroster or the floor.
As far as the "not too cool," are you sure it isn't low on freon? Is the compressor cycling?
Jun 11, 2010 at 4:42 PM
