1997 Ford Aerostar
120,555 MILES • 6 CYL • 2WD • AUTOMATIC
IH560NUT
I have a check engine light on which is saying left bank is running lean according to Auto Zone. The van starts good and seems to run just fine. Sometimes when you slow down to stop; it makes a howling noise. I shut off the AC fan and switched the system to off still noise. I accelerate to go and the noise stops. I don't notice the noise at highway speeds just in town travel stop and go. What should I be looking at to further diagnose this problem?
Jun 10, 2010 at 4:31 AM
  • 110,248 POSTS
It sounds like a vacuum leak. If it is bad enough, you could hear a hissing and it will cause a lean mixture. Check under the hood for disconnected, damaged or dry rotted hoses.
Let me know what you find.
Jun 11, 2010 at 4:44 PM
IH560NUT
This is what I have found. The Air charge sensor has been stripped of its threads so that is where my noise is coming from. I put silicone around the threads and my noise lessened and the idle evened out no surging. I haven't found another air inlet tube yet but I will be using an adhesive compound to make the fix more stable.
Jul 1, 2010 at 1:29 AM
  • 110,248 POSTS
That is what is causing your lean mixture. Let me know if you have other questions.
Jul 1, 2010 at 2:02 PM
