1996 Ford Aerostar power window
18,000 MILES • 6 CYL • 2WD • AUTOMATIC
YASIN
Hi my passenger side window does not work
windows is down now when i push down to button
there is little sound like (click) when i pull up window button there is no any sound and movement
i checked electric on window controller there is electric.
may be i have to change power window motor but there is no any nut or screw for to take out
is there any thing I have to check
I need help what i have to do
thanks
Apr 21, 2010 at 6:15 AM
  • 110,248 POSTS
Have you checked to see if the motor is getting any power? As far as removing the window, there are rivits that hold the original ones in plsce. THey need drilled out and replaced with nuts and bolts.
May 1, 2010 at 7:13 AM
