1996 Ford Aerostar Overdrive light on shift lever blinks
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
JTMONIZ
The overdrive light on my shift lever blinks every once in a while, and when it's blinking, transmission has a hard time working properly. Pull over, turn the vehicle off, turn it right back on again, and it's no longer a problem. Is this a fuse or a wiring problem??
Jul 13, 2008 at 2:45 PM
BMRFIXIT
  • 19,053 POSTS
tranny problem ?
you need to check tranny for codes as it telling u you have an issue in it and it need to be checked
its a wide possibility (relays ,solenoids , clutches , … )
codes will narrow it and pin point it
good luck
Jul 13, 2008 at 3:15 PM
