Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Aerostar
Interior
Instrument Cluster
Gauges
Oil Pressure
1996 Ford Aerostar oil gauge
1996 FORD AEROSTAR
17,600 MILES • V8 • 2WD • AUTOMATIC
ECPELLY
MEMBER
1 POST
Driving down the road the oil gauge goes past the the highmark what could be causing this?
Mar 13, 2008 at 4:38 AM
Experienced Mechanic
The oil pump pressure relief valve might not be opening or the oil pressure sending unit is out of calibration
Do an actual oil pressure check with a mechanical gauge -if normal replace the OPSU
Mar 13, 2008 at 5:16 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
