Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Aerostar
Exterior Light
Headlight
Switch
Replace/Remove
1996 Ford Aerostar Headlight switch
1996 FORD AEROSTAR
256,000 MILES • 6 CYL • 2WD • AUTOMATIC
DLONG179
MEMBER
1 POST
How do you change a headlight switch in a 96 ford aerostar
Jan 30, 2009 at 4:33 AM
DAVE H
Experienced Mechanic
MULTIFUNCTION SWITCH
Removal & Installation
Disconnect negative battery cable. Remove steering column shroud. Remove retaining screws. Disconnect multifunction switch connectors. Remove switch. To install, reverse removal procedure.
Jan 30, 2009 at 4:59 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
