1996 Ford Aerostar Headlight switch
1996 FORD AEROSTAR
256,000 MILES • 6 CYL • 2WD • AUTOMATIC
DLONG179
How do you change a headlight switch in a 96 ford aerostar
Jan 30, 2009 at 12:33 PM
DAVE H
  • CERTIFIED EXPERT
  • 13,384 POSTS
MULTIFUNCTION SWITCH
Removal & Installation
Disconnect negative battery cable. Remove steering column shroud. Remove retaining screws. Disconnect multifunction switch connectors. Remove switch. To install, reverse removal procedure.
Jan 30, 2009 at 12:59 PM
