1996 Ford Aerostar areostar 3.0
1996 FORD AEROSTAR
UNIQUE
Engine Mechanical problem
1996 Ford Aerostar Two Wheel Drive Automatic
My 1996 areostar would not start after no starting problems used a bob scanner got code for camshaft position sensor replaced item still won't start replaced crankshaft sensor still no start. Removed #1 spark plug brought cyl. up on compresion stroke removed crank shaft center bolt made sure key way was straight up used alignment tool on cam postition syncronizer reinstalled to original position still no start engine spins and pops but will not start. Help!!!
Apr 17, 2008 at 3:27 PM
MUSTANG87
  • 261 POSTS
try changing the ignition control module and check gas filter. go to kragen.com or get one from a junkyard to save money icm can fit from almost any aerostar or cars for example crown vic mustangs and more.its all the same
Apr 19, 2008 at 10:38 AM
