HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Aerostar
Engine
Serpentine Belt
1996 Ford Aerostar
LOUISSSE
MEMBER
1996 FORD AEROSTAR
6 CYL
AWD
AUTOMATIC
90,000 MILES
Looking at the engine the drive belt is moving but the power steering wheelis not.
Wednesday, December 17th, 2008 AT 5:57 PM
MECHANIC
Hi:
If I under stand, the power steering pulley isn't turning. Is that correct? Do you have any power assist when you turn the wheel?
If no, the pump seezed and will nost likely need replaced.
SPONSORED LINKS
Tuesday, December 30th, 2008 AT 12:08 PM
Please
login
or
register
to post a reply.
Related Serpentine Belt Content
1996 Ford Aerostar Timing Belt
How Do I Adjust Timing Belt When It Has Slipped?
Asked by
Dan Kepple
1 ANSWER
1996
FORD AEROSTAR
Oil Change
How Many Quarts Of Oil Do I Need To Do An Oil Change On My Van?
Asked by
davis_c1202
1 ANSWER
1997
FORD AEROSTAR
Thoughts On Engine Control Module Causing Weak Or Dead...
I'm Having Trouble With My 1992 Ford Aerostar Van. And I've Discovered The Injector On The Number One Cylinder Isn't Working. What Are...
Asked by
George Green 5280
1 ANSWER
1992
FORD AEROSTAR
Roaring Noise From Air Intake
Hi, I Have A 1997 Areostar, 4.0. That Has This Awful Roaring Groaning Noise That Comes From The Intake Area From The Air Filter Housing To...
Asked by
olddragracer
1 ANSWER
FORD AEROSTAR
Engine Swap
Will The 6 Cyl Engine From A 96 Aerostar Fit In A 95 Without Major Problems? Thanks!
Asked by
RB
FORD AEROSTAR
VIEW MORE
SPONSORED LINKS
How to Replace Serpentine Belt Toyota Prius
Serpentine Belt Replacement Ford
Serpentine Belt Replacement Chevy 1500
Online car repair manuals
