1995 Ford Aerostar Rear Vents
95,000 MILES • V8 • FWD • AUTOMATIC
SCOTTYEVAN
The heater is working in the front vents but will only blow cold to the back of the van. What should I check for this please.
Thank You,
Scott Harries
Jan 8, 2010 at 2:04 AM
MERLIN2021
  • 17,250 POSTS
Probably a clogged rear(auxillary) heater core, radiator shop can try high pressure flush, or you can buy a Prestone flush kit, install the Tee in the rear cores heater hose, clamp off the end toward the front, dissconnect and clamp the return hose, and flush by turning on the garden hose, watch for any crud to come out of the core, the radiator shop can do a way better job of this, and would be worth the money!
Jan 8, 2010 at 7:34 AM
