1995 Ford Aerostar Performed a tune-up, now van running wor
1995 FORD AEROSTAR
MCCRANEY05
Engine Performance problem
1995 Ford Aerostar 6 cyl Automatic
My husband replaced the plugs and the wires, distributor cap and R-button...however when we started the car at first, it sounded nice but when we went to drive around the block, it had no "get up and go", tok time to get into gear and back fired constantly. Once we got home, i turned it off for him to take another look and now the van wont start....I need to go to work and I am stuck...please help with any ideas:) Thanks
Follow up:
Waited 15 minutes, went out and tried to start it again, after many tries, it tried to roll over 3 times but had no fire catching to continue the start of the engine....
Nov 29, 2008 at 9:50 AM
DOCFIXIT
  • 18,828 POSTS
Check dist cap see if it on good also rotor . And check firing order ie. wire on right plug.
Nov 30, 2008 at 8:26 AM
