1995 Ford Aerostar no heat
1995 FORD AEROSTAR
FIREMAN123CA
Heater problem
1995 Ford Aerostar 6 cyl Two Wheel Drive Automatic
my van wont heat up does a little bit but temp gauge wont go to half the engine fan is running steady new parts for the heating system what can i do to get the engine run at opperating temp
put a new one in still wont heat up inside the vehical going to try a new one 205 i had put a 195 but still blowing cold air anything else it could be...........
Nov 15, 2008 at 5:13 AM
  • 110,244 POSTS
Hi:
The temp sensor is most likely the cause of the fan problem. As far as the eng, replace the thermostat.
Nov 21, 2008 at 4:18 PM
