1995 Ford Aerostar hydraulic leaks
12,800 MILES • 6 CYL • 2WD • AUTOMATIC
ISLANDROSSINFLORIDA
Have had rear brake hardware kit, new brake master cyl, new rear wheel cyl installed. After the van was brought home I noticed there were two lights lit. The ADS yellow one and the red Brake too. Took it back in and the shop chief came out looked at the lights, opened the hood and looked, went back inside and came back with a bottle of brake fluid which he poured into the brake reservoir. I could see that there was not very much fluid in it, but he said that there might have been a "slight hydraulic leak" but he said there was enough fluid in it but when the fluid sometimes sloshes back and forth it probably triggered the sensor in the unit. He added some fluid and the lights eventually went off. I later found out from this site that there is a max fluid level mark on the unit and there was no way the amount of brake fluid was even close to that mark, so I filled it to the max level. Today I noticed that sitting at a stop light with my foot on the brake pedal, the pedal very, very, very slowly moves downward toward the floorboard...so I suspect there might be a small leak somewhere. My question is...if he thought there might have been a slight leak, shouldn't someone have checked for any leaks when they were doing the repairs?
Aug 4, 2009 at 6:08 AM
DONALDGOLDSR
  • 38 POSTS
A definite YES.
Dont go back to the people who did all that brake work. If your peadl is sinking with constant pressure, that is usually a faulty master cylinder. I read that you had that replaced already, but there are 2 things that couldve happened, here. 1) the new cylinder was defective. 2) the brake pedal was pushed to the floor more than once, which ruined the seals inside the new master cylinder.
They are only designed to be pushed so much. If the bore is pushed so far that the seals go past the inlet or outlet holes, then, the new master cylinder will be ruined...
Aug 4, 2009 at 3:03 PM
