Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Aerostar
Brakes
Master Cylinder
Reservoir
1995 Ford Aerostar fluid level
1995 FORD AEROSTAR
12,800 MILES • 6 CYL • 2WD • AUTOMATIC
ISLANDROSSINFLORIDA
MEMBER
1 POST
How do you determine where the proper fluid level is in the brake fluid reservoir?
Aug 3, 2009 at 6:01 AM
Experienced Mechanic
HI there,
there will be a max & min level indicator on the reservoir, but if not full will be around 5-10 mm from the top of the container.
mark (mhpautos)
Aug 3, 2009 at 10:53 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
