1995 Ford Aerostar floor air vents do not work, and gas ped
1995 FORD AEROSTAR
DFLICKINGER
Heater problem
1995 Ford Aerostar 6 cyl Two Wheel Drive Automatic
I have an 95 Aerostar with an 3.0 engine
this morning the floor air vents stoped working
the other vents work and the blower is working, but air does not come out
the second question is the gas pedel is getting harder to push. It seems to get harder to push in cold weather
Thanks for your help
Nov 17, 2009 at 4:46 AM
  • 110,244 POSTS
It sounds like you have a vacuum leak. The vent doors are actuated by engine vacuum. If there is a leak, the direction of the air is affected. As far as the throttle. Check under the dash for leaks. With the engine running, you may hear a hissing sound where the leak is.
Check to make sure the cable is in good condition and lube it if needed.
Jan 23, 2010 at 4:08 PM
