how do you put on a power stern pump on a 1995 ford Aerostar
Nov 3, 2008 at 11:36 AM
✓Experienced Mechanic
Hi:
Disconnect the battery, remove the belt, remove both the hi and low pressure hoses, unbolt the PS pump and remove. Reverse sequence to replace. Also, you will need to fill the pump with PS fluid before starting. Once started turn the wheel until the pump begins to prim and refill the pump until it no longer goes down.
