1995 Ford Aerostar Air Conditioning Clutch No Power
1995 FORD AEROSTAR
TIROCH
Air Conditioning problem
1995 Ford Aerostar 6 cyl All Wheel Drive Automatic
Clutch will not activate in any of the 3 position of the fan control. Clutch coil has electrical continuity. No voltage in the power plug at the compressor. Cleaned wiring harness contacts in both plug assemblies.
I'm wondering if it is the fan switch or is it the pressure (?) switch attached to the pot just above the compressor.
May 4, 2008 at 6:06 AM
MASTERTECHTIM
  • 4,750 POSTS
its usually because of the low pressure cut out switch has low freon level. its located on the receiver dryer. thats the football looking thing near the firewall.
May 4, 2008 at 6:30 AM
