1995 Ford Aerostar ABS LIGHT
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
CANJA
My ABS and brake light stays on and my speedometer doesn't work. I heard that this all ties in together, is that true? I have change the speed sensor and check the master cycler, wireing plug from the master cycler. I've heard that it may be the ABS control module. Where is that located? Is there a way to clear the code in the module.
Nov 9, 2009 at 11:03 AM
  • 110,248 POSTS
Have you had the computer scanned to determine where the problem is coming from?
Jan 23, 2010 at 4:18 PM
