1995 Ford Aerostar
NATIVESTARBURST
1995 Ford Aerostar All Wheel Drive
my van keeps bogging when given gas. i have changed the fuel pump, fuel filter, and the fuel pressure regulator; no change in the way it runs. when van gets going it will lose pressure somewhere and car starts bogging and losing pressure and when i press on the gas it will most times do nothing. HELP PLEASE!
since this is a free question i will wait patiently for your response
Sep 11, 2010 at 1:40 PM
  • 75,988 POSTS
Thank you for your patience-see below:
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Sep 11, 2010 at 2:05 PM
