1994 Ford Aerostar Won't shift into overdrive
SARRADD
Transmission problem
1994 Ford Aerostar 6 cyl Automatic
1994 Ford Aerostar 3.0 liter V-6 Won't shift into overdrive. I haven't tried anything yet to fix it, will check fluid and filters...any ideas? Please help!!
Aug 7, 2008 at 10:54 AM
KHLOW2008
  • 41,812 POSTS
Hi Sarradd,
Was the CEL showing?
Most probably the 3-4 shift solenoid is faulty.
Aug 16, 2008 at 5:21 PM
SARRADD
We tried to find the 3-4 solenoid, we weren't sure if it was on outside or not, he got completely frustrated and took it to shop. They fixed it, not sure what they found. I will put it here when I find out in case it helps anybody. Thank you for your help.
Aug 21, 2008 at 7:12 AM
