1994 Ford Aerostar Trouble Shooting
136,896 MILES • 6 CYL • 2WD • AUTOMATIC
PUREGHOL
It first started I was drivng along and started loosing power and then it started running like ti needed a tuneup then it would pick back up and run fine for a couple of miles. Now once it starts it runs for about 4 mins. sputter and die. I replaced the MAF semsor and the fuel filter (the fuel filter was almost totally clogged). I hooked-up the code reader because the Check Engine has been on since trouble started and it acts like it is going to test the system but it does not send any codes Please help any info would be Greatly Appreciated.[img:2daea01119]http://www.2carpros.com/forum/automotive_pictures/137079_Pimp_out_Aerostar_1.jpg[/img:2daea01119]
Jan 1, 2008 at 7:54 AM
STEARMAN22
  • 6 POSTS
I would check for more fuel filters to be replaced. normally look for
1. Just before the injectores or carb.
2. under the running rails of body.
3. just out of the gas tank.
If that does not fix you may have to rebluild your injectors or carb.
Skid
Jan 1, 2008 at 8:13 AM
