1994 ford aerostar shifting problem
TGAROFALO1
I own a 1994 ford aerostar. It will not shift into park I need to start in neutral. When I stop and shift the lever into park it will only reach reverse. Is this a neutral safety switch problem?
Jan 30, 2007 at 5:30 AM
TAZMANIAC_37752
it is most likely you linkage cable is just out of adjustment have sumone check the adjustment on the transmission and if still dosent work check the cable on the shifter end too
Mar 31, 2009 at 2:55 AM
