My aerostar will overheat and coolant sprays out of the hoses on the left side of engine leaving a huge pool of coolant on ground by front right tire. looked around water pump housing and could not see a leak there. Replaced thermostat-no help. Also the transmission started not going into gear same time as overheating and friend thinks may be related? Had complete transmission flush and gasket changed but problem still there.
Mar 20, 2009 at 5:25 AM
