1994 Ford Aerostar Overheating and spewing coolant and not
155,000 MILES • 4 CYL • 2WD • AUTOMATIC
BSALINAS
My aerostar will overheat and coolant sprays out of the hoses on the left side of engine leaving a huge pool of coolant on ground by front right tire. looked around water pump housing and could not see a leak there. Replaced thermostat-no help. Also the transmission started not going into gear same time as overheating and friend thinks may be related? Had complete transmission flush and gasket changed but problem still there.
Mar 20, 2009 at 5:25 AM
INKD4LFE
I just had the same problem last week, check the hoses behind the tension pully, my hose split and leaked everywhere and my trany started to act up too, I bought a some new hose and a T fitting along with a 2 male fitting, about $14 at auto zone, it's 5/8 inch hose by the way, check all the hoses there. good luck...
Jun 9, 2009 at 5:08 PM
