THE CRANKS WILL NOT START. THE FUEL PUMP IS RUNNING BUT THE VAN STILL WILL NOT START. ANY SUGGESTIONS?
Mar 6, 2008 at 6:50 AM
✓Experienced Mechanic
1994 Ford Aerostar NO START
Do you mean it cranks over and refuses to start or won't crank at all?
If it can crank-do this spray into the throttle body with a starting fluid and see what happens then report back-
Mar 6, 2008 at 7:02 AM
BBILLY
MEMBER
THANKS FOR YOUR REPLY -- I SPRAYED THE STRATING FLUID IN THE THROTTLE BODY & SAME THING - CRANKS BUT NO SPARK.
JUST AN FYI - IT HAS BEEN PARKED OUTSIDE IN SOME COLD TEMPERATURES AND AN ICE STORM. ALSO IT HAS NOT BEEN DRIVEN FOR A FEW DAYS BUT RAN & STARTED PRIOR - POSSIBLY A CONCIDENCE WITH THE TEMPERATURES?
Mar 6, 2008 at 7:18 AM
Lets look for spark-disconnect a sparkplug wire and ground it to the engine and have helper crank engine over-do you have spark?
