headlights keeps blinking off and on when I am driving or at idle but when I pull back on the mechanism and hold it there it is fine help
Apr 30, 2009 at 12:21 PM
19PINTO71
MEMBER
The headlight switch has a built-in circuit breaker that trips when it overheats and resets automatically when it cools. It sounds like the switch has a bad (dirty)contact inside. If you want to save money(not time)take the switch out and spray inside with WD 40 and work the switch several times. Sometimes this prolongs its usefullness. If the problem continues, replace the switch.
