1994 Ford Aerostar fuel pump
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
AEROSTAR OWNER
I recently had the fuel pump fail in my aerostar after running it with little fuel and filling it on a very cold day. After taking it out and testing it again I found that it worked and the van runs well arain now. How long to fuel pumps usually keep running after quitting and being revived.
Jan 31, 2009 at 4:36 AM
  • 110,246 POSTS
Hi:
When they are bad.... they usually are done. If yours is working again, I would feel more confident saying that you had a loose or dirty connection that was cleaned or repaired when you did the work. The pump is an electric motor. When worn out, they usually are done.
Let me know if you think this is possible.
Feb 8, 2009 at 5:09 AM
