1994 Ford Aerostar engine won't turn completely over
AEORSTAR1994
Electrical problem
1994 Ford Aerostar 6 cyl All Wheel Drive Automatic
1994 ford aerostar van fuel pump went out, parked for 3 months, replaced fuel pump, now engine won't turn over to start, took starter out & replaced it, replaced battery but van still will not turn over. Took starter off & replaced it turned flywheel manually but it stops, will not turn all the way and make complete cycle it wouldn't go anymore. Help please on how to get the engine to crank up motor will not turn on completely it stops 3/4 of the way. (engine will not crank over for van to start, engine will only turn 3/4 of the way & engine will stop, hard to turn even manually)
May 19, 2008 at 2:42 PM
  • 75,988 POSTS
Engine could be partial seiged
Pour 1/2 can of coca cola in each cylinder give it atleast 2hrs to soak in-than manually turn the crank again give all you got-unable to turn crank 720degs time to go in the engine and investigate
May 19, 2008 at 5:54 PM
