1994 Ford Aerostar Engine Sputter
1994 FORD AEROSTAR
114,000 MILES • 6 CYL • 2WD • AUTOMATIC
HUNTERDAN
When the engine is first started it will run fine for a few seconds. Then it will idle down and sputter; nearly shutting off, before recovering for about 30 seconds and repeating the cycle. Now the engine is skipping heavily.
Nov 29, 2008 at 1:49 AM
  • 110,244 POSTS
Hi:
Check fuel pump pressure. You can rent the tool at many of the nationally recognized parts stores.
let me know what you find.
Dec 30, 2008 at 7:18 AM
