1994 Ford Aerostar drin plug
167,000 MILES • 6 CYL • AWD • AUTOMATIC
DAVEDIONIZIO
i wood like to change my transmission fluid but i dont see a drain plug where is it location and does it hold 10 quarts
Jul 23, 2009 at 11:35 AM
  • 110,248 POSTS
There is no drain plug. The fluid comes out when the trans pan is removed. Loosten one side, then remove the bolts from the other side slowly so it drops slowly and the fluid doesn't go everywhere.
As far as the capacity, when you remove the pan, you will loose around 4 quarts of ATF. Most of the fluid stays in the torque converter and throughout the rest of the trans.
Aug 6, 2009 at 4:01 PM
