1994 Ford Aerostar Coolant leak
179,000 MILES • 6 CYL • 2WD • AUTOMATIC
RICKOHIO
My 1994 Aerostar sprays coolant all around the side of the engine compartment by the heater fan. No coolant smell in the interior when heater is on though. Happens intermittently (hard to predict), when engine is hot and radiator is full. Is there some kind of high pressure relief valve there? Suspect I filled radiator to top, instead of adding to reservior. Also, temp gauge cycles up and down about a third of it's travel over a period of 20-30 seconds. Is there too much coolant in the radiator, too little? Level is down maybe an inch below top of fins right now, and that is when the coolant gauge cycles.
Jan 29, 2008 at 11:50 PM
MERLIN2021
  • 17,250 POSTS
Best thing to do is get a pressure test on the cooling system, there may be a small tear in a hose by the heater...you should have a recovery tank, add water to the cold fill line! Radiator is low if fins are exposed!
Jan 30, 2008 at 12:53 AM
