1994 Ford Aerostar CONTROL MODULE
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
JBRIT87
I DON'T HAVE POWER TO #2 AND #4 AT CONTROL MODULE. I HAVE PRIMARY POWER, BUT NO SECONDARY POWER TO COIL AND NO SPARK. I HAVE PROPER VOLTAGE AND PROPER IGNITION SUPPLY AT COIL. WOULD MY PROBLEM BE IGNITION OR COMPUTER?
Mar 20, 2010 at 1:57 PM
  • 110,251 POSTS
Chances are it is the PCM. However, I would recommend having the coil checked before replacing it. If you take it to a nationally recognized parts store, they should be able to help you.
Apr 8, 2010 at 1:18 AM
