1994 Ford Aerostar Blown head gasket on a 3.1 V6
1994 FORD AEROSTAR
107,000 MILES • 6 CYL • FWD • AUTOMATIC
DAVID_T
I woiuld like to know if it is better to just replace the engine than to spend the time fixing a blown head gasket on one side of a v6 or would it be better to replace both head gaskets because I've been told that if you only fix the one side that later on the other side will blow and you will be back to the same problem that you just fixed!! Thanks.....
Aug 26, 2009 at 2:49 PM
  • 110,244 POSTS
With only 107K on the engine (if it was maintained), I would replace the head gaskets (both).
Sep 10, 2009 at 2:59 PM
