1993 Ford Aerostar Unable to find exectrical problem that k
13,000 MILES • 6 CYL • AWD • AUTOMATIC
BENT WRENCH TIME
I've taken my 1993 Ford Areostar Van to the repair shop twice and both times the mechanic has been unable to located the electrical problem that is draining the battery. Do you have any ideas or suggestions as to what may be the answer to my problem? Everything works fine its just that in a couple of days the battery goes dead.
Oct 22, 2008 at 1:25 PM
BENT WRENCH TIME
[quote:58c089bdeb="bent wrench time"]Engine Performance problem
1993 Ford Aerostar 6 cyl All Wheel Drive Automatic 130,00 miles
I've taken my 1993 Ford Areostar Van to the repair shop twice and both times the mechanic has been unable to located the electrical problem that is draining the battery. Do you have any ideas or suggestions as to what may be the answer to my problem? Everything works fine its just that in a couple of days the battery goes dead.[/quote:58c089bdeb]
Oct 22, 2008 at 1:32 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, here is what you can do to figure out what circuit the drain is on.
1) If you don't have one purchase one. A test light.
2) Remove either the Positive or the Negative Battery Terminal. One or the other not both.
3) Take the test light and connect it between the Cable and the Battery Terminal. The test light as long as there is a draw on the battery will light. It may be very dim if it takes a few day to run battery down.
4) Turn Key to On Position do not start the vehicle.
5) Start pulling Fuses one at a time Checking Test Light with each Fuse Pulled if light still on replace fuse. When test light goes out check what circiut that it runs.
Post finding here in forum.....
Oct 22, 2008 at 1:47 PM
