1988 Ford Aerostar dead battery
101,000 MILES • V8 • 2WD • AUTOMATIC
FGARDEN
A good battery died overnight. After recharging the battery the van started ok and ran ok and alternator charging ok. Then with engine off we found a 3.8 amp current draw with the ignition and all accessories off. We pulled all the fuses in the fuse block under the dash and the 3.8 amp draw was always there. Starter solenoid is ok. Is there something that commonly shorts out on an Aerostar?
Thanks.
Jul 3, 2008 at 12:35 PM
MERLIN2021
  • 17,250 POSTS
If all fuses were pulled and the draw is still there, remove the BATT wire from the alternator, if the draw is gone replace the alternator.
Jul 3, 2008 at 12:39 PM
FGARDEN
We left the battery disconnected over the 3 day holiday but found the short gone from the alternator when we went to replace it this Monday morning. We moved the ignition switch from on to off to lock and started and stopped the engine but can't get the 3.8 amp short to reoccur. Can a shorted alternator be intermittent?
So with the alternator charging just fine and no leakage current back through it, the aerostar was put back in service only to have the alternator burn up at 3PM, as in smoke from it's windings and needing a dose from a fire extinguisher. Maybe it was a piece of metallic debris moving around in a winding?
Jul 7, 2008 at 6:54 AM
MERLIN2021
  • 17,250 POSTS
I've seen a lot, not too surprising,we now know without a doubt the condition of the alternator...
Jul 7, 2008 at 11:54 AM
