1993 Ford Aerostar Turn Signal lights don't work at all.
1993 FORD AEROSTAR
80,960 MILES • 6 CYL • 2WD • AUTOMATIC
TOMTHUMB1
PROBLEM:
The Turn signal and hazard lights won't light up at all.
SYMPTOMS:
I am able to hit the brake lights, and they work (both the tail lights and the center rear window light).
I am able to put car into reverse and the reverse lights come on.
I have purchased a Electronic Flasher replacement part, at the suggestion of the parts store attendant.
QUESTION:
If this is the right part to replace and solve this problem, where is it located and how can it be replaced?
Am I all wet? : ) THanks.
Aug 8, 2009 at 5:31 AM
  • 110,244 POSTS
The flasher is either in the fuse panel in the vehicle or under the hood in the power distribution center. It just plugs in.
Sep 11, 2009 at 1:06 AM
