1993 Ford Aerostar stalling
PEAFISHNUT99
Electrical problem
1993 Ford Aerostar 6 cyl Four Wheel Drive Automatic
we have allready made a donation but you wanted to know what we have tried the link you sent in the email wont work so im trying again we have done a tune up and a wiggle test the altinator was changed about 9 months ago we changed the mass air flow sensor and it still stalls if it is pluged in with the mass sensor unplugged the van will run but stalls at stop lights untill its warmed up then it dosent stall we are at aloss on what else it could be
Sep 27, 2009 at 2:44 AM
  • 110,248 POSTS
Does the check engine light come on? Have you checked fuel pump pressure? Vacuum leaks?
Oct 20, 2009 at 2:44 AM
