1993 Ford Aerostar Rear Wheel Bearing
BIGJOHN10
Tires and Wheels problem
1993 Ford Aerostar 6cyl Two Wheel Drive Automatic 200000 miles
What would be the approximate total repair price for replacing the bearing and seals (rear passenger side) for 1993 Ford Areostar, large 4.0 ltr. It has showing 200000+ miles (Motor replaced), so mileage not accurate. Passenger side rear wheel bearing replacement?
Thanks...John
Apr 7, 2010 at 3:50 AM
  • 110,246 POSTS
The cost of parts will be around 100.00 plus 2.5 hours labor.
Keep in mind, with that many miles, you may need to replace the axle due to wear.
Apr 7, 2010 at 2:03 PM
BIGJOHN10
[quote:fdee974a2e="Jacobandnickolas"]The cost of parts will be around 100.00 plus 2.5 hours labor.
Let me know if you have other questions.[/quote:fdee974a2e]
OK...with the following:
BEARING AND SEALS (right rear)
GREASE SEAL =12.99
AZ R AXLE RPR BRG ASSY = 87.60
LABOR =138.00
SUBTOTAL =238.59
AND
DIFFERENTIAL SERVICE - NON SYNTHETIC 75W-90
LIMITED 100 LIMITED SLIP DIFFERENT FLUID =14.99
WASTE OILS DISPOSAL FEE = 2.00
GGN 90 NON SYNTHETIC 75W-90 GEAR GLIDE =19.99
DIFFERENTIAL SERVICE LABOR =50.00
SUBTOTAL = 86.98
PLUS =238.59
TOTAL =325.57
This then, seems to be inline with an average price schedule?
Thanks for your time.
John
Apr 7, 2010 at 2:23 PM
  • 110,246 POSTS
John:
That does seem really close. I wouldn't say they are taking advantage of you. Keep in mind, to replace a rear axle bearing, you need to remove the axle which takes time. To do it, the differential has to come apart, rear brakes...
Apr 8, 2010 at 12:39 AM
BIGJOHN10
[quote:549666bee0="Jacobandnickolas"]John:
Joe[/quote:549666bee0]
Hey Joe,
I didn't want to close this issue, without saying "Thank You" for your info.
Best wishes to you and yours.
John
Apr 8, 2010 at 3:39 AM
  • 110,246 POSTS
John:
I'm glad to have helped you. If there is anything in the future we can help with, let us know.
Thanks for using 2carpros.com and best wishes to you and yours too.
Apr 8, 2010 at 3:24 PM
