1993 Ford Aerostar no brake pressure
135,000 MILES • 6 CYL • 2WD • AUTOMATIC
WILLIAM BARR
My brakes went to the floor the other day,so I checked the line,front drivers side was blown so I replaced it.I bled the lines and still no pressure on the pedal.Just when it acts like it is building up it goes to the floor.If I press hard it acts like it wants to build pressure,then goes to the floor.
Feb 15, 2009 at 6:35 AM
  • 110,244 POSTS
Hi:
Check the rubber brake lines to make sure they are not expanding. Also, check for other leaks and check the master cylender.
Feb 24, 2009 at 1:43 AM
