My 93 Aerostar will run fine when cold once it has warmed up it will skip on 1 cyl when you restart it. If you let cool it will start and run fine. The engine does not use oil, no smoke, no odd noises from the engine. I have done a complete tune up (wires, plugs, cap, rotor, ect) I have no check engine lights, no codes what so ever. I done a compression check all cyl have 140-145.
I'm leaning towards a fuel injector shutting down what do you think?
Nov 10, 2008 at 12:43 PM
